Leaking diesel drop by drop
   / Leaking diesel drop by drop #1
Glen Spey, NY
John Deere 410B Backhoe/Loader
Hi,
Our 410B has been leaking diesel since we started using it again (it had probably not been used a few months) back in February. Now that I've been using it a little more regularly, the leak is becoming worse.
I had the good fortune of someone showing me how to use the machine awhile back, but unfortunately I haven't been trained on repair and maintenance (other than what I read in the operations manual). Although, I do know it has been greased and the oils changed about a year ago.
The leak is coming from DSCN9498.jpg this, almost from the top of it, on the right side. It's dripping at a rate of about 1 drop every 4 seconds. Here's a closeup: DSCN9499.jpg
Any help at all would be much appreciated. I thought it would be quite simple - such as a clamp that needs tightening, but I couldn't seem to find anything like that in this area; although maybe I missed it. Thank you so much for reading and your support.
Jeremy
   / Leaking diesel drop by drop #2
What you have is a Lucas CAV injector pump. They were used on many different engines through the years.
It sounds like yours has a throttle shaft leak. There are many threads online discussing this common problem.
Thanks so much. I'll have a look at those threads. Really appreciate it.
2016 CHEVROLET 2500 TRUCK (A54756)
2016 CHEVROLET...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
2016 Sakai SV540 Padfoot Compact Roller (A54865)
2016 Sakai SV540...
2013 John Deere 650K Crawler Tractor Dozer (A55787)
2013 John Deere...
BUNDLE OF 2" X 2" X 22" ANGLE IRON (A54756)
BUNDLE OF 2" X 2"...
