Leaking fittings
   / Leaking fittings #11
do double check fittings types and make sure that if you have taper fittings they are ntp or ntpf
   / Leaking fittings
So if there tapered what coupler should I be using?
   / Leaking fittings #13
I would make sure of the fitting . water line rarely is exposed to 3000psi. The fitting would not be weeping if you had the correct set up. In some cases the tape can be dangerous floating around.
   / Leaking fittings #14
If the fittings are tapered, they are NPT, then use NPT fittings.
As far as Teflon tape on hyd fittings, it is general practice to not use it. The reason is that the tape will shred when loosen, and most people don't clean out the threads. and small bits of Teflon is pushed into the hyd flow and can jam up things in the hyd circuit.
Teflon paste is recommended or Loctite red or blue.
Npt fittings were not designed for repeated coupling, Each time you tighten, the threads are deformed a little more. Maybe 2 to 3 tightening and loosening.
Your best bet is to switch over to JIC fittings, and tighten the NPT one good time. JIC does not need Teflon.
   / Leaking fittings #15
+1
You may have over tightened the fitting the very first time and deformed the threads too much and that's why they leaked
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
