leaking o ring
   / leaking o ring #1
waldrip10
Mitsubishi D3850fd
I have a Mitsubishi D3850fd that leaks hydraulic fluid around the o ring at the lower end of the steering column. I have replaced the o ring once and it continues to leak.
   / leaking o ring #2
check the seating area and or the shaft around which the oring seals / seats.. pits, cuts , gouges or wear marks can make it inefective.
also.. are you using an oem oring replacement or a 'will-fit' from a universal kit... many oem styles can have a different profile but near same dimensions as kit orings, and cause problems if not repalced with a correct oring..
soundguy
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
