Leaking Steel Line
   / Leaking Steel Line #1
F350
USA
Red
I have a steel power steering line that consists of the line, a compression fitting, and a barrel nut. The line connects to my steering box. The problem is fluid is leaking from between the line and the nut. I've tightened the line, but it still leaks.
Any repair tips other than having to replace the line?
   / Leaking Steel Line #2
you might try backing the nut off then re-seating it..
   / Leaking Steel Line #4
I have fixed leaking flare compression fittings by wrapping a couple turns of cotton string around the flare, then tightening the nut back onto the fitting. Cotton string about 1/16th inch in diameter worked for me, and you may have to try several times to get the right amount of string so the nut will go on the fitting. PS fluid might dissolve other types of string. Hope this helps.
   / Leaking Steel Line #5
I am a new tractor owner, and I have a hydraulic leak on my 3 points, the power steering and 3 point should use the same hydraulics. I ordered the tech manual from Deere and read through the entire hydraulic theory and repair section. Not as interesting as it sounds. Anyhow every single page usually multiple times says if you are repairing a hydraulic leak you must replace the o-rings, used o-rings leak. The other thing they stress is proper torque levels so cranking down on something maybe just as detrimental as not having it tight enough. I am taking my 3-point leak into the shop since its under warranty and the service manager has agreed to let me watch and help with the repair, since I think I know how to do it, it should be educational. All that was to say maybe you need a new o-ring lol, good luck.
   / Leaking Steel Line #6
IMHO. once compression fittings leak.. you need to repalce parts..
soundguy
   / Leaking Steel Line #7
soundguy
Yep...you can try bandaids (the cotton string), but you may as well get a replacement line on order.
   / Leaking Steel Line #10
Thanks for the links on those seals, I didn't even know such an animal existed.
STORAGE FEES (A56129)
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
2013 Ford F-550 Passenger Bus (A55852)
2013 Ford F-550...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55302)
NEW HOLLAND 706 30...
Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
Kubota RTV-1140...
BUYERS PREMIUM & PAYMENT TERMS (A56138)
BUYERS PREMIUM &...
