LED aftermarket lights on lawn tractor
   / LED aftermarket lights on lawn tractor #11
I have the powerflo so I vacuum every time I mow, However, when I clean the areas out near the house (bushes, shrubs, beds) it gets into a wide wind row going around three sides of the house, I have to take only a third of the deck at a time, with many passes. I am looking at a separate vacuum system with a hose.
I have contemplated also getting the hose kit with the Cyclone rake. I can't recall where, but I read somewhere that the new Husky GT48DXLS has so much ejection force from the deck that you don't need a powerflow unit for a large capacity bagger. I don't know about that, since I have never tried it, but I can vouch that the ejection force on that unit is surprisingly strong.
I have a large gravel driveway area where I do not want to drive the mower on, for the obvious reasons. Instead of a hose bagger, someone suggested using a backpack blower to blow all the leaves off the gravel (and out of the planters) onto the lawn, and then drive the mower/bagger over the leaves on the lawn. I'm going to try that. But it will be Fall before I can report how well it works.
   / LED aftermarket lights on lawn tractor #13
I have a small hand held blower also and have rented a back packer to clean out around the house, my only complaint is that it blows a lot of the mulch out also, so I think a vac with hose and hand clean will be better at that. The problem is wet leaves tends to stick to the ground (be it cement, pavement, grass, gravel or dirt).
202483 (A54757)
202483 (A54757)
Electric Mobility Scooter (A55853)
Electric Mobility...
2018 FORD F-350 (A55745)
2018 FORD F-350...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
Portable Restroom (A54865)
Portable Restroom...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
