LED Trailer Lights
/ LED Trailer Lights #1
GaryBDavis
Andice, Texas
I’m building another trailer and am once again considering using LED lights.
I use the oval tail/brake lights and 2 inch round clearance lights that mount with the rubber grommets. I’m still using the sealed beam lights as they are cheap, easy to find, and for the most part, different brands look pretty much the same so you can interchange them.
The LED lights are still kind of expensive and different manufacturers have different LED patterns for the same size lights. I was kind of hoping they would all settle on one configuration so they could be somewhat interchangeable. But, it doesn’t look like they are there yet.
Anyone out there have a brand recommendation that seems to be the most popular and on-line supplier that carries them?
/ LED Trailer Lights #2
I highly recommend Peterson Manufacturing. Not only are they probably the most popular, they have a 100,000 hour
rating (not sure if it's actually a guarantee). I bought a bunch of LED marker lights from them, and a few died because they were close to the ground and I think
salt water got into them during Winter, and I called them to complain and they shipped out new ones at no charge. They only asked that I send the old ones back so they could check them for manufacturing defects. They have a web page here
www.pmlights.com You can call them and ask who is selling them in your area or ask them for a web site. I asked them for a web site for the marker lights and they gave me www.4statetrucks.com which is a place that primarily caters to 18-wheelers, but they had the lights I wanted and gave me great service. Many of the LED lights require pigtail connectors, so make sure you check into that and buy them if necessary.
/ LED Trailer Lights #3
I love LED's on vehicles. They are bright, and under normal circumstances they don't burn out.
Anyway, if you want to roll your own, a friend of mine put together homemade LED lights for his mustang, and they came out excellent. Last summer I duplicated his project for my F350... and they too came out really nice.
http://www.midimonkey.com/~frederic/taillights/
Might be more work than it's worth for most, but it was a fun project none the less.
/ LED Trailer Lights #4
I think the best feature of the LED light is..... that it does not have a high amp draw.
Ronald
/ LED Trailer Lights #5
What are you building this time Gary? I'm kicking around building a 22' myself, maybe using 2X4 tubing for the frame.
/ LED Trailer Lights #6
LED lights also burn cooler than an incandecent bulb. Although the LED's last much longer keep in mind that the majority of lighting failures on trucks and trailers are from corroded terminals and other connections. I used to work in the Heavy Duty Truck Lighting Division of a Tier 1 supplier and corrosion has been the #1 cause of failure for years.
The best combination seems to be an LED light with terminals coated with dielectric grease and protected from salt or water spray.
/ LED Trailer Lights #7
The demise of most trailer lights I have seen are due to collisions and abuse, not bulbs burning out or corrosion. The led's might keep on burning after the housing is broken away /forums/images/graemlins/smile.gif
Ben
I will probably try some soon though, they are getting cheaper.
/ LED Trailer Lights #8
LMAO, good point.
Though my trailer lights usually do burn out because I've welded simple metal shrouds around them for protection.
While rather bent at this point, the housings are okay!
/ LED Trailer Lights #9
I installed a set of LED lights on my home built utility trailer. I got mine at the local Northern Tool, and they probably sell them on line. I forget the brand name of the lights I bought. I think I have also seen them at the local Tractor Supply Co. store, so you can probably get them on line there too.
Although the lights are probably worth more than the rest of my trailer (I've had it 20 years), I like them 'cause they burn brighter than the former standard lights. The lower amp draw also means they wont screw up your turn signals if you don't have a HD "blinker."
/ LED Trailer Lights #10
Frederic, I would be interested in seeing your schematic to see exactly how you handled the dim -vs- bright states of the LED's.
I bought some no-name aftermarket LED taillight bulbs that were direct replacements for the 3157's, and they burned out after six months. My idea in putting in LED's was to make them last for the life of the truck, and instead I had people yelling at me that I had no brake lights. Sigh.
I'm building a new welding trailer. Nothing fancy - except the LED lights.
I ended up buying Optronics brand. That's what they were pushing at the local trailer parts place. The oval tail/brake were $28 for the 48 diode kit (grommet and wiring lead). The 2 inch clearance lights were $6.66 with four diodes each.
I would have prefered to get Peterson as they've are popular, but they didn't have any I liked. The Optronics come with a lifetime warranty. Hopefully, I won't crack the housings when I'm backing it into the barn.
/ LED Trailer Lights #12
<font color="blue"> I bought some no-name aftermarket LED taillight bulbs that were direct replacements for the 3157's, and they burned out after six months. </font>
Sounds like they forgot to build in or at least send the resistor that goes inline with a led to make it work on a 12v system. Led usually like about 3.5 to 5 volts and more makes them burn out very quickly.
/ LED Trailer Lights #13
Most LED's are current sensative. A good design has a current regulator and a small resistor in series with each "string" of LED's just in case one of the LEDs burn out. This prevents the other strings from sucking too much current until you can replace the burned out LED.
/ LED Trailer Lights #14
Frederic,
I found the link to the schematic on your web site. One thing I do not see is a part number for the LED's themselves. Realizing that there are hundreds of types of LED's out there with various sizes and intensities, is there a particular LED that you feel is best suited for this application? I think I'm going to make my own LED tail lights for my truck.
/ LED Trailer Lights #15
Although it would take more parts and real-estate, wouldn't a better design be to have a current limiting resistor for each LED so that if one burned out, NONE of the others would go out?
/ LED Trailer Lights #16
Mike -
You can use any high brightness red LED that's in the 8000-1000 mcd range, that requires 20ma nominally and provides a 2V drop.
I used Kingbright LED's simply because I snagged a huge pile of them on Ebay and this facilitated my life-long desire to be cheap.
Here are the ones I used:
http://www.us.kingbright.com/product.asp?catalog%5Fname=LED&category%5Fname=X%2Dbrite+LED&product%5Fid=W7113SEC%2FH
http://www.mouser.com sells them. I believe http://www.digikey.com does as well.
With the LED's in a parallel/series arrangement, you need less current to drive them all. Also, each LED in series provides a 2V drop (or so) for that string. Since you have 12V more or less, this is useful as it makes the circuit less complicated.
Lets say you have 40 LED's in one taillight. In a series- parallel arrangement you'd have 10 strings of four, so you'd need a little over 200ma to drive the taillight (20ma * 10). If you ran them all in parallel, with a series resistor, you'd have 40 * 20ma, for 800ma total draw. 600ma is not a whole lot, however you're getting closer to the 1a limit of the voltage regulator (operating as a current regulator), therefore it will get hotter, and require a heatsink. Excessive heat (and a heat sink) inside a plastic taillight may or may not be a problem, depending on the volume of air contained, and if the taillight has a metal backing that the regulator can be attached to (in an insolated fashion of course) to transfer heat out of the regulator.
You could use a larger regulator too I guess if you want to run them all in parallel, instead of a heat sink. Then you have to change the schematic a bit to compensate for the lack of voltage drop across the strings.
LED's last forever if you don't provide too much current - and this circuit does just that - so the series-parallel arrangement is "good enough" to last decades. I'm sure your truck will be recycled into toasters long before the LEDs burn out.
/ LED Trailer Lights #17
Good info, thanks. I am just a bit leery of series arrangements though. Kind of like christmas tree lights...which one opened up the circuit ?
Ben
/ LED Trailer Lights #18
Fair concern.
However, xmas tree bulbs are good for about 200 hours. LED's are easily good for 40000 of lit time. Triple that figure with half the nominal current.
How many hours are your taillights on? ;-)
/ LED Trailer Lights #19
Actually my tail lights are on when the engine is running. I run my headlights all the time and the running lights with them.
Ben
/ LED Trailer Lights #20
Okay. Lets do some math then!
Let's say you're driving your truck 4 hours a day. Two hour commute each way to/from work. There are 200 workdays in a year, so that's 800 hours the LED's would be lit.
Out of 40,000 hours minimum life ;-)
There are only 8760 hours in a year, so even if you ran your truck and left the LED's on 24/7, they'd last many, many years.
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
25026SFL (A61569)
25026SFL (A61569)
CARRYALL 1700 UTV (A64280)
CARRYALL 1700 UTV...
RoGator and Terragator Manuals (A63117)
RoGator and...
