Length of battery cables??
   / Length of battery cables?? #11
Gareth
You're from South Africa.
Hey come along and register. I need some non-US support on TBN. We are few are far between !!
Cheers
   / Length of battery cables?? #12
Gareth,
I ran cables down the frame of my truck to connect my winch to the rear hitch. Welding cable is what I used. I picked that because it is so flexible. Any "type" cable should be fine as long as it is the correct size.
   / Length of battery cables?? #13
I don't know what wire sizing system you use in S.Africa but there should be a wire size printed or cast in the insulation. Here in the US it would say something like 2/0 AWG for American Wire Gauge. Does your cables have something like that near where it says 1000 volt welding wire?
i fitted the new cables and she crankes like a petrol engine, thanks for all the info. she cranks fast but doesn't want to start and i think it is because air got into the system somehow when i tried to start her with the old battery cables, had very little diesel in the tank! i tried to bleed her now and one of the screws broke off so i just spent about an hour getting it out!!
when does the torment end???
regards
gareth
UNUSED AGT TIRE CHANGER (A51244)
UNUSED AGT TIRE...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
John Deere 9450 Combine (A50514)
John Deere 9450...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2022 JOHN DEERE 26G EXCAVATOR (A51242)
2022 JOHN DEERE...
