gemini5362
Veteran Member
Soundguy I get your message about not useing a store bought driveline. To be honest the people I talk with and am around see nothing wrong with scabbing one together. I personally agree with that. If it comes apart then you have two things you have the driveline connected to the brushhog that is going to spin until the brushhog stops spinning it is going to bounce around a bit but the three point hitch on the brushhog is going to keep it from going very far. The section on the tractor is going to spin until you push in the clutch and it coasts down. I dont see either of those sections hitting the driver of the tractor. It might happen but it does not seem to be something that makes the papers every day. The odds of someone getting hit by a drunk driver and killed are a lot higher than being injured by a broken driveshaft. If a person really really is worried about it breaking then get a piece of thick wall pipe bigger than the pipe you are welding. slide it onto your driveshaft all the way down to the end. Weld your piece lengthening the driveshaft then slide the pipe back over the entire welded area and weld it on the ends. If that breaks and kills you then it was probably your turn to die no matter what you are doing.
