Let it run or off and on
   / Let it run or off and on #1
logan97
Blue Ridge Mnts, Va
Kubota B7800 4/wd
while doing various chores around the Homestead much of the time I will need maybe 5,10,15 minutes to accomplish a task. Should I leave the K B7800 running or turn it off and re-start it. In the long run is it better,worse, or does not matter to the Engines well being?
   / Let it run or off and on #2
This has been discussed in the past. For me 15 minutes or less I leave it running. If the wind chill is -25 degrees and I'm in the middle of the pasture a half mile from the house I leave it running all the time.
   / Let it run or off and on #3
My B21 seems to get warmer after I turn it off. I tend to let it run at idle so the fan continues to cool it.
   / Let it run or off and on #4
If you are going to be less than 10 min between chores I would leave it idle at an increased rpm to keep the temp up and stable. Anymore than 10 minutes and the fuel wasted out ways any saving on starter motors etc.
   / Let it run or off and on #5
10 mins or more I shut engine down,when temp below 30F or so I like to keep engine running.
   / Let it run or off and on #6
@BruceWard: Some reading I did (Four Stroke Performance Tuning by A Graham Bell) suggested that coolant temperature increasing after an engine stops is normal.
There's the issue of cylinder wash....I have nothing to back this up but it's generally accepted that diesel engines stand up to excessive idling better than gasoline engines do on account of cylinder wash, isn't it? On the subject: I once heard a fellow from Caterpillar say to avoid extended idling but if an engine needed to be left running for extended periods, to "bump the rpm's up a bit"
For me, a big part of it is how hard it is to start the equipment and how hard the engine was working in the minute leading up to the stop. If it needs a lot of cranking I'm more inclined to idle the engine for short stops and if it's been working hard I'll let it idle for a minute or two before turning it off.
My Chevy welding truck kicks over in an instant and I have no issues with killing the engine for the shortest breaks.
Of course, on cold days....
   / Let it run or off and on #7
One other thing to add to the equation of thought...
If you are unlike most of the members here and your tractor sits all alone without use for a week or 2 or 3... then when your using it, those extra minutes idling can be a good thing to keep the battery charged..
alot of starts can drain it,, but an extra 30 minutes of run time over the day can help..
J
   / Let it run or off and on #8
Mechanical issues aside, I just can't get comfortable dismounting a tractor while it is running. I realize it can be done safely, but old habits die hard or in some cases not at all.
   / Let it run or off and on #9
I can certainly see that, esp in cases of precarious parking or mobile implements left running. In the cold light of day tho I have to consider the times we use tractors to apply stationary power without a bit of worry about the tractor itself doing anything unpredicted. -- PTO gen, pump, hay elevator, wood chipper, post driver, ... etc. How can this be any different than getting off a parked idling tractor? Quality of the parking job is the only thing I can see.:confused3:
larry
   / Let it run or off and on #10
larry
Oh, I didn't say it made sense nor that it couldn't be done safely, just that in my 60's, having spent my formative years and later on old iron without much in the way of safety features, it is just hard for "me" to feel comfortable doing it.
It doesn't bother my sons a bit as all they have ever used is modern equipment with brakes that actually work, safety switches etc.
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
20ft x 7ft Bi-Parting Galvanized/Powder Coated Metal Gate (A59225)
20ft x 7ft...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
2007 Chevrolet Silverado Service Truck, VIN # 1GBHC24K77E577417 (A57453)
2007 Chevrolet...
