Let's ROCK..[Where is the rock capital?]
   / Let's ROCK..[Where is the rock capital?] #11
   / Let's ROCK..[Where is the rock capital?] #12
Re: Let\'s ROCK..[Where is the rock capital?]
That's it, I give up, you win! /forums/images/graemlins/smile.gif
   / Let's ROCK..[Where is the rock capital?] #13
You gave up too easy. Heres another. I tried the box scraper but the front tires came off the ground.......................Don't understand it>>>>>>>>>>
   / Let's ROCK..[Where is the rock capital?] #14
The limestone is a bugger bear for putting in fence posts. But I've got an eight inch auger that treats it like a good auger treats hard clay, nothing but a thing. /forums/images/graemlins/grin.gif
The way we set posts in country like Johnk's is we use a diesel air compressor and a rock drill. We drill a hole a little bigger in diameter than the post one and a half times the diameter in depth. We set the post with a hydraulic cement like QuikRok.
But the absolute worst conditions for setting fence posts is sand and pebbles in combination. We found this at the foothills in southern Califiornia at the edge of the valleys.
A conventional posthole auger will bounce around and out of line. If you do get it to go down the walls cave in.
So the way it worked then, thirty years ago, and I don't see how it could have changed much, was posthole diggers and water. Water to pack the sand and the hand diggers to pick out the stones one at a time. It was a bugger bear only a bugger bear mother could love. /forums/images/graemlins/tongue.gif
   / Let's ROCK..[Where is the rock capital?] #15
</font><font color="blue" class="small">( Water to pack the sand )</font>
Harv, when I was doing gas leakage surveys, we used a 5/8" steel rod, slide hammer type gadget to punch holes in the ground, sometimes through asphalt paving, then a fiberglass tube connected with rubber tubing to a combustible gas indicator. You draw, or pump the gas through the instrument with a squeeze bulb, and in sand, as you said, the sides cave in and you'll just suck sand into that fiberglass tube. So the small amounts of water to pack the sand is what you do in that case. I got a bit of experience with it in West Texas. /forums/images/graemlins/wink.gif
   / Let's ROCK..[Where is the rock capital?] #16
I don't know if you've ever been to a place like Palm Springs California. It's sugar sand. So to dig holes you carry a five gallon bucket of water and wet the hole as you go down. And you don't wait too long before setting the post and you almost tip toe around the hole until the concrete is in. Used to love working there. /forums/images/graemlins/tongue.gif
   / Let's ROCK..[Where is the rock capital?] #17
<font color="blue"> "..so let's see pics of those rocks!"
</font>
I'm only 2 months late. Here is my rock it was sticking one foot out of the sugar sand so I dug around it. took me a couple of months.
   / Let's ROCK..[Where is the rock capital?] #18
Yep, there is a tractor behind that rock. Can't move it. Guess I'll cover it up. /forums/images/graemlins/grin.gif
   / Let's ROCK..[Where is the rock capital?] #19
I'm in the same boat as OkeeDon, except around here it is clay, not sand. I was raised in central Texas & when I bought my 1st house in New Orleans after I was married, I remember going out to the back yard to find some rocks to put in the bottom of a potted plant. Surprise - - Nada. No rocks here at all. Guess that's the result of the way the Mississippi delta was formed.
Quick Attach Pallet Forks (A47384)
Quick Attach...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
Case 721B (A47384)
Case 721B (A47384)
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
(11) 8' Treated Posts (A50515)
(11) 8' Treated...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
