Leveling a mobile home question.
   / Leveling a mobile home question. #11
Single wide should be much easier. If you use the laser shot down one end, I dont think it matters where it is as long as it's level and reaches the distance you needd. The you can measure from the line to any points that are consistent, even the top of the beam, middle of the beam ect tra
   / Leveling a mobile home question. #12
OK, I miss read it:p
Getting a cheap one at Lowes (less then $100, or renting one may be an option?
Or a cheap bore sighter on a straight 2"x4" may do it
Sorry for the confusion on my part.
Yep.No lazer level.May be a future purchase.I decided to raise the MH above grade and then use the water level to fine tune the level.Well guess what!?My 20 Ton jack won't budge the MH.I had all tie downs loose,utilities dug up,and sewer drain line dug out.Nothing holding it anywhere.I guess my jack has an internal leak.Oh well.I threw in the towel and called in the pro's.I hate to spend the money.It cuts into rebuilding the floors and remodeling the MH.This will be a rental so I'm not going to throw a lot of money into it.It will be nice,but not overly so.You know,just a bit better than the original MH 70's styling it came with.:laughing:
20701 (A55853)
20701 (A55853)
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
