leveling attachment for field cultivator
   / leveling attachment for field cultivator #1
browning1
new holland tc40
I have frontier 3pt 6ft field cultivator that i aquired thru a trade and i would like to put a leveling attachment on it. I have a heavy chain mat that i pull right now and it does ok in my clay dirt. Has anyone built or bought a buster bar or rolling baskets for this cultivatos? I would appriate any pics if anyone has any.
   / leveling attachment for field cultivator #2
I have one of these cultivators and would question whether it would have the dirt cut up enough to use a rolling basket. Ground conditions would have to be just right. A bar or comb with aggressive teeth hinged over the frame might help and would not interfere with the 3pt operation.
The dirt gets broken up real good with a disc first.I mainly use it as a finishing tool before i row up my garden. All the farmers around me use the unverferth perferta II field cultivator with rolling baskets as a finishing tool so i wouldnt think mine would be any different. The chisel points have been changed to the danish tine type sweeps already so that hopes it to.
   / leveling attachment for field cultivator #4
If the ground is worked up enough then a rolling basket may work for you. I use a land plane grader blade in most of my jobs to get the ground smooth and remove any depressions or cut off mounds. I use a 3ph spike tooth harrow afterwards to cover seeds and to remove any other marks.
If you do build a rolling basket it would be good to see how it works out for you.
   / leveling attachment for field cultivator #6
First couple pics are from some work I did in one pasture. It didn't do so well on root clumps but the regular drag harrow took care of those. Last pics are from a ball diamond I helped rehab. The diamond was as hard as the city street when I started. Took multiple trips in different directions to break it up but as you can see it busted the clods down nicely.
[/URL[URL=http://s1238.photobucket.com/user/Idafrog/media/IMG_0941_zpsb6578095.jpg.html]
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
*Selling at Royal Auction Tampa, FL Location* (A59230)
*Selling at Royal...
