lever on back of e2004 is it autotill or what?
   / lever on back of e2004 is it autotill or what? #1
agcomike
southern states
Hinomoto e2004 aka 5020
I have a e-2004 hinomoto on back below the lift arms is a lever on right hand side looks to go into the hydralic cylinder looks to have hole for a pin what is it for? i thought maybe a tiller or something?
   / lever on back of e2004 is it autotill or what? #2
That would be your draft control. If you have the factory tiller, there will be a cable going from that lever to the tiller. When the tiller goes over a bump or in a hole it tries to level itself.
Eugene
wonder if you could rig something up to make other implements work with it? I have a sub soiler that tends to sink in..
thanks...
   / lever on back of e2004 is it autotill or what? #4
Yes, it could work on anything. However, you will need the rest of the parts that go with the lever.
Eugene
do you know what it looks like? if it just lifts when the lever lifts i can probaly just fab something up..
   / lever on back of e2004 is it autotill or what? #6
The cable looks like a choke cable, only larger. The other end is attached to the rear lid that covers the tines. When a mound of dirt pushes against the lid, it pushes the cable towards the tractor and the hydraulic lift compensates for the variation in the terrain.
Eugene
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
20711 (A50323)
20711 (A50323)
WOODS RT48.30 LOT IDENTIFIER 219 (A53084)
WOODS RT48.30 LOT...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
