Lift Arm Spacer(s)
   / Lift Arm Spacer(s) #1
hthomure
Central Missouri
Kubota B2910
Hello all. I've searched for this topic, and only found one thread on it, and it never really got resolved, so I'm going to resurrect it.
I was messing with my lift arms the other day and happened to notice that one arm has a spacer where it attaches to the PTO, but the other arm doesn't. I just assumed both arms need one, so I started the search process to find one to order. While searching is when I discovered the discussion as to whether or not both sides needed a spacer. I know my mowers pull to the side all the time, and I was thinking that might be the cause. But now since I discovered this discussion I'm not so sure. Attached is a photo of what I have currently. Yes my tractor is filthy.
Thanks for any help.
   / Lift Arm Spacer(s) #4
Yup, supposed to be on both sides.
   / Lift Arm Spacer(s) #5
You do need another on the left side.
Have your dealer order one for you.
SDT
   / Lift Arm Spacer(s) #6
Make one from a piece of pipe.
   / Lift Arm Spacer(s) #8
Have to remove lift arms to install backhoe. Lost one spacer. Cut about 1/4” off a standard cat 1 to cat 2 sleeve from any tractor supply store.
Have to remove lift arms to install backhoe. Lost one spacer. Cut about 1/4 off a standard cat 1 to cat 2 sleeve from any tractor supply store.
Ooh, I like that idea. Thanks.
Kubota Diesel Tractor (A57453)
Kubota Diesel...
250 Traffic Cones (A57454)
250 Traffic Cones...
UNUSED INDUSTRIAS AMERICA EASY MAN CATTLE RAMP (A58375)
UNUSED INDUSTRIAS...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
