Lift disc
/ Lift disc #1
Tomas
I have a 10' Ford double gang lift disc and need some help. The back gang is skating across the top of the ground and not doing much. On a lift disc, are the wheels supposed to be off the ground in the down position, and is there an adjustment to control the depth of the back gang?
Many thanks.
/ Lift disc #2
Many thanks.
Your wheels are supposed to be up in the air if you have a pressure in/ pressure out hyd valve on your tractor that will raise the wheels. Most wheel discs have a spring loaded adjustment in the middle of the disc to put more or less pressure on the back gang. Ken Sweet
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
CASE INTERNATIONAL 893 - 6R36" CORN HEAD (A63291)
CASE INTERNATIONAL...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
