Lifting welding tanks
   / Lifting welding tanks #11
Be careful about lifting compressed gas cylinders by their caps. Most of these cylinders are decades old and can have damaged threads that will allow a cap to be threaded on, but won't hold the weight. There are also coarse and fine thread caps & cylinders also. A cross threaded cap can come loose. Many a tooth has been chipped by lifting or moving a cylinder only to have it pop loose.
   / Lifting welding tanks #12
Have you ever moved a appliance with a set of hand trucks? Perhaps you should custom design a New cart, That works like a hand truck, roll the cart up to the tanks slightly tilt the tanks forward just enough to slip the carts bottom plate underneath, Then you can tilt the cart slightly back allowing the tanks to settle in place to strap them on, Actually I had made a cart from a set of hand trucks as I have described, Though I cannot provide a Photo, It got where I was rarely using them so I sold the cart and tanks, downsize to the smaller tanks,
Here's you an idea, take the welding cart you already have cut the bottom loose and weld it back in place on a hinge, also have a small steel cable attached to the bottom sides and routing it up along mid-way of the sides of the upright, put you a small winch with a crank handle, a flip of the lock loosens the bottom so that you can slide it under the tanks, now turning the winch handle will easily lift the tanks into the cart,
Portable Restroom (A54865)
Portable Restroom...
(INOP) 2015 JOHN DEERE GATOR TURF UTV (A51406)
(INOP) 2015 JOHN...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
PAIR OF 5' CLIP ON TRAILER RAMPS (A54756)
PAIR OF 5' CLIP ON...
New Swict 72" Skidloader Material Bucket (A50775)
New Swict 72"...
2017 Kia Sorento SUV (A55758)
2017 Kia Sorento...
