Lightning and cows
   / Lightning and cows #41
My Dad had a veterinary practice in Michigan, and would get calls about lightning strikes on animal. Most were cattle, because it was mostly dairy in the area. Not much could be done other then treating the wounds as you would burns, but the nervous system damage wasn't really treatable. Sorry you lost your bull.
   / Lightning and cows #42
Hmmm, never heard the four legged thing before.
You should take short steps, to minimze the diffrence in potential on the ground, if you ever at big electrical fault, and the ground is being energized. Electrical substations are supposed to use the exact size stones in the yard, though some don't.
The resistane of the ground varies, how dry it is, type of soil, gravel, and size of gravel.
   / Lightning and cows #43
Farmers can be the worse for grounding. That is one reason they so many problems with stray voltage. They are the self reliant type, which I respect. But you need to learn the right way to do things. What seems small to you, may have a reason.
The code even says which way to wrap a wire around a screw, to tighten it correctly.
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
