Limited CAT 1 and CAT 1
   / Limited CAT 1 and CAT 1 #11
So sence CAT O seems to be preatty much dead, and a lot of the new class of subs comming with a smaller CAT1, maby its time for a new size. Maby a CAT .5? Maby something a bigger CAT O tractor could use, and a smaller CAT 1 tractor could also use. Have a swapable pin/bushing setup. Just a thought.
   / Limited CAT 1 and CAT 1 #12
Are the pin sizes on a limited Cat 1 the same as a conventional Cat 1?
Does "limited" refer to range of motion, max height, etc. only?
OkieG
   / Limited CAT 1 and CAT 1 #13
I think it has been mentioned one way or the other, but the limitation is in the range of motion and weight capacity. The Limited Cat 1 hitch on the 2210 is a Cat one hitch for all dimesions of the ASAE spec. JD did take a hint from one of the only problems with the BX hitch--max width/spread of lift arms on the BX was too tight for some standard Cat 1 implements, and that's resolved with the 2210's lift. I think the biggest limitation comes from wheel size (machine height) and the inability to use some implements with a deeper "draft' like bigger post hole diggers, middle busters, or rippers, without dragging the implement in the dirt even at the highest lift setting.
   / Limited CAT 1 and CAT 1 #14
<font color="blue"> I think it has been mentioned one way or the other </font>
Pete,
Thanks for tackling my question head-on. /forums/images/graemlins/smile.gif I just hate it when posters don't do a better job of reading my mind. Sometimes I have to dust off the keyboard and ask my question straight out. Can be embarrassing to peg the stupid question meter. Why can't they just answer the question I have in my head and not make me post it? These days it's hard enough to read the lines much less read between them. Some days are better than others.
OkieG
   / Limited CAT 1 and CAT 1 #15
You're not alone, OkieG. My problem is that I start reading threads from the most recent message, then work my way back to the question. Bad habit...kinda' like a dysfunctional version of Tractor Jeopardy with Alex Trebeck
   / Limited CAT 1 and CAT 1 #16
<font color="blue"> My problem is that I start reading threads from the most recent message, then work my way back </font>
Oh...is that a bad habit? I thought everybody did that. /forums/images/graemlins/smile.gif
   / Limited CAT 1 and CAT 1 #17
uh it's not proper to read the last post first /forums/images/graemlins/confused.gif
KBH 25T Tender (A56435)
KBH 25T Tender...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
2015 Freightliner M2 106 4x4 Altec DM47B TR 47ft Digger Derrick Truck (A55973)
2015 Freightliner...
2002 International 9200i Truck (A56435)
2002 International...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
