Lincoln Weld Pack 3200HD Gas Mig Welding Questions
   / Lincoln Weld Pack 3200HD Gas Mig Welding Questions #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Yesterday I bought a like new used Lincoln 3200 HD mig welder. I have it all setup with gas. This unit has an adjustable gas valve on it. I also own a Lincoln Weld Pak 100 with the non adjustable gas vavle. For some reason I can't get this welder to work anywhere near as good as my Weld Pak 100 does. Does anyone out there own this unit or a Weld Pak 135 and know what they use for a gas setting on it? The machine works fine with standard flux core wire. It just doesn't seem to work right with the gas setup. The valve does work as gas does come out of the welding gun. I bought this fairly cheap to replace my Weld Pak 100. The 3200 HD is supposed to have 35 more amps of welding power. Now I'm wondering if that is just a bull line or what. I'd like a 220 volt unit, but right now my funds are pretty limited. This machine will have to do for the meantime.
   / Lincoln Weld Pack 3200HD Gas Mig Welding Questions #2
Try asking your question on the Miller Motorsports Welding Forum or the Hobart Welding Forum. Each of these forums discuss Lincoln equipment and there are quite a few posters there that own Lincoln equipment. You will get your best answers from the pros at either of these forums.
All set. First thing I should have done was to reverse the polarity. New toy runs like a dream now.
   / Lincoln Weld Pack 3200HD Gas Mig Welding Questions #4
Jim I did the same thing with a Hobart 120 I just sold, welds looked like **** I thought something was really wrong...it was ...me /forums/images/graemlins/frown.gif.
I bet you'll never do that again /forums/images/graemlins/grin.gif
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
19200 (A50324)
19200 (A50324)
