lincoln welder can't turn knob
   / lincoln welder can't turn knob #11
I have an old Lincoln tombstone welder which overheated and the switch not only stuck, but it broke.
I fixed it by pulling it apart, drilling through the broken parts, driving a long steel screw and some epoxy through it, and then carefully sanding down the epoxy until it was the original part dimension, and then I lightly sanded down the 'clicker-clutch' on the front which reduced the total pressure required to turn the switch.
It is easier to turn now, but I realize that it would have been better to have used a high temp epoxy...
I just do not have any, and did not have time to wait for any.
Should it overheat in the future, I will use high temp glass filled epoxy and some high temp fiberglass builder's rod and make a copy of the original part, since you can not purchase said original part by its self, but instead have to purchase the entire switch assembly which is more than I paid for the welder AND a HELL of a lot of work because you have to carefully disconnect the old one, lead by lead and reconnect it, which needs special crimping and uncrimping tools. [pausing to breathe]
Once you know what you are doing, its not super difficult, just a little bit of a wait while the epoxy cures.
IF you get to the problem BEFORE the part melts enough to STICK internally, you could possibly put some pipe Teflon around the area as a heat shield and prevent part failure. That is what I would have done if I had known what the problem was sooner.
I made a sloppy 2 part video of the repair, if people want to see how it is done, just post a response here and I will upload them and post them so you can see it in action.
   / lincoln welder can't turn knob #12
I had one of those tombstone welders with a problem with the amp selector switch so may not be the same as yours, but it was fixable. I took it apart and found some of the nylon and swelled enough so that it wouldn't let the contactor slide up and down on the nylon shaft. A little sanding removed enough to free up the mechanism. Then i cleaned up the contact points and used some contact clean/lubricant on it. Eventually i gave the welder to my nephew and it's still going strong.
It was my father's, bought in early 70's if my memory is correct.
Wow, one of my old threads resurrected.
Our welder switch still doesn’t turn, but hasn’t been used in years.
   / lincoln welder can't turn knob #14
My old Lincoln is old,45 yrs or more. Not a pro but thick metal and a handful of 7018s worked for me. LOL
2019 ALLMAND LIGHT TOWER (A58216)
2019 ALLMAND LIGHT...
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
78in Quick Attach Smooth Bucket (A57453)
78in Quick Attach...
Honda UTV (A56859)
Honda UTV (A56859)
John Deere 5055E (A53317)
John Deere 5055E...
