Linseed oil on trailer decks
   / Linseed oil on trailer decks #1
bigdad
Platinum Member
West Central Illinois
Kubota B7510
Anyone use Linseed oil on their treated trailer decks? Someone gave me four gallons and figured that I could use it on the trailers.
   / Linseed oil on trailer decks #2
Might be slick when wet. Try a small section first.
   / Linseed oil on trailer decks #3
linseed oil comes in two types, boiled and raw, neither of which are very good finishes. They offer almost no water protection, they polymerize slowly and are very soft, and really don't give you any protection, so in my opinion, you are wasting your time, and worse, creating a situation that might be detrimental to the adhesion of future finishes.
   / Linseed oil on trailer decks #4
I second what the last guy said. I see people put it on wood for boat and it does not work out. You would be better off using it somewhere else and using old diesel oil and some diesel fuel mix to coat your trailer.
Chris
   / Linseed oil on trailer decks #5
Linseed oil is what they use (or used to use) to make oil based paint. I don't think it penetrates all that well. Think of porch deck paint. Probably wouldn't hold up on a trailer deck.
One trailer I bought, the fellow recommended a mixture of diesel and ATF.
   / Linseed oil on trailer decks #6
I have seen that mixture used with good success.
   / Linseed oil on trailer decks #7
used motor oil works quite well on wooden trailers. and it's free.
recently used boiled linseed on an old porch swing, then painted it with oil based alkyd paint. worked great.
amp
Thanks Gents....
We always had to use it on wooden ladders and tool handles and I never saw that it was that effective then. Just something we were told to do. Ha!
Thought it might be a way to get rid of some FREE oil product. Again, Thank you.
   / Linseed oil on trailer decks #9
Well if it's free then I quess you won't be out anything?
I have also used the diesel and ATF worked okay. Used oil mixed with a thinner of some sort would proabaly be better.
   / Linseed oil on trailer decks #10
Does anyone know the reasoning behind the diesel and ATF mix vs. using one or the other alone?
Ken
2017 Takeuchi TL12V2 Skid Steer (A59213)
2017 Takeuchi...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
1993 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1993 Ingersoll...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 Ford Transit 250 (A57148)
2018 Ford Transit...
(INOP) MASSEY FERGUSON 2614H RIDING MOWER (A58374)
(INOP) MASSEY...
