Liquid Nails,, Construction Adhesive,, Which One!??
   / Liquid Nails,, Construction Adhesive,, Which One!?? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
I have been adding insulation to my basement concrete walls, by attaching foam panels to the concrete with Liquid Nails.
All went well, and the insulation is REALLY attached to the concrete,,
Well, yesterday, I decided one wall needed more insulation thickness,,
so I "Liquid Nailed" a second thickness (2") of the EPS foam board to the first,,
Well, the Liquid Nails never "cured" over night, the adhesive was still as liquid as it came out of the tube.
I read the tube, the instructions state that one of the materials must be porous,,like wood. concrete,, etc,,,,
In this case, both materials were foam board, so neither was porous,,, :confused:
I know I have to be careful to make sure the adhesive I select must be rated for foam board, so that the adhesive does not melt the foam board.
Do you have any recommendations as to what the correct adhesive might be for this non-porous to non-porous bonding application??
There is only about a hundred different tubes of "stuff" to select from when I go into Lowes,,,:confused2:
   / Liquid Nails,, Construction Adhesive,, Which One!?? #2
That Lepage PL adhesive is pretty impressive stuff. Dropped a dime sized blob onto my concrete apron, and later had difficulty kicking it off with my boot!
   / Liquid Nails,, Construction Adhesive,, Which One!?? #3
Use the glue that's recommended for foam panels. It will say right on the tube.
   / Liquid Nails,, Construction Adhesive,, Which One!?? #5
I agree. You have to read the labels to see what it will work on. I'm surprised liquid nails didn't work.
   / Liquid Nails,, Construction Adhesive,, Which One!?? #6
   / Liquid Nails,, Construction Adhesive,, Which One!?? #7
I actually asked for and have a tube of adheive for foam. Never used it.
Lepages PL 300 "Foam" board.
"Won't burn through foam".
Can't say if it's any good. If it's as good as the regular PL it should be good.
   / Liquid Nails,, Construction Adhesive,, Which One!?? #8
I actually asked for and have a tube of adhesive for foam. Never used it.
Lepages PL 300 "Foam board".
   / Liquid Nails,, Construction Adhesive,, Which One!?? #9
If that doesnt work plain old contact cement, just make sure it's were you want it because you don't get a second chance.
   / Liquid Nails,, Construction Adhesive,, Which One!?? #10
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
Bobcat T250 Skidsteer (A54865)
Bobcat T250...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
