lithium battery for more air flow.
   / lithium battery for more air flow. #11
My A/C has issues on my L4060. But every time I check it's because the condenser is plugged. Dust & dirt packs in there pretty good at times. Its not always that obvious either.
I wouldnt get a lithium battery for a tractor. I have one that would likely fit that I got for mobile HAM radio stuff. Charging voltages are different enough you shouldn't swap the 2 types unless you get one designed for drop in automotive type use with a proper charge controller.
Yep, our BX2660 radiator packs full happily but its not obvious until it the needle starts going up...
Aaron Z
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
Portable Restroom (A54865)
Portable Restroom...
VINTAGE JOHNSON MOTOR (A58374)
VINTAGE JOHNSON...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
DEUTZ MARATHON...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
