Load capacity of railroad ties
   / Load capacity of railroad ties #21
You also need to consider the flow of the stream and how high off the water you will be. If you get flash floods or high flows it can wash your bridge downstream if it is not anchored to the abutments.
As for the design I would suggest using three posts (railroad tie) at each abutment one at each end and one in the center. Then lay one tie across these posts parallel to the stream and anchor it to the posts. This will be the support system. Then lay your railroad tie deck perpendicular to the stream. If you can drill holes through the ties at 3rd points that line up all the way across and put a threaded rod through it and put a nut and washer on each end. This will make them act as one beam and you won't have to worry about the extra load of the deck on top of your beams.
Dave
Dave - I agree with your abutment design. I have heard about using a threaded rod to tie the deck together. However, if I make the deck 8 or 10 feet wide where do I find galvanized threaded rods that long? I guess I could have threaded ends welded to a long rod but I still would need to find long rods. Not sure where to go for something like that. Also, what diameter rod would I need?
   / Load capacity of railroad ties #23
Rebar. Comes in 20 foot lengths.
I have smooth rod 10-20 feet long all over this farm, but can't say where it would come from these days. Used to be common to hold buildings together, etc. Actually, it's all around old concrete silos.... /forums/images/graemlins/wink.gif
--->Paul
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
JOHN DEERE LOADER BRACKETS FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE LOADER...
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
