Loaded tires vs wheel weights
   / Loaded tires vs wheel weights #11
Cowboydoc,
Why wouldn't you use a 3 pt ballast weight? Just curious.
Advatage to 3pt ballast weight is that you can adjust the center of gravity by raising or lowing the hitch.
Terry
Terry,
I don't use a "3-Pt Dedicated Ballast Weight"...
The same as Richard, I use an "existing implement" as the ballast.
I agree with Richard, invest your money in an implement you can use for dual purposes, such as a heavy rear blade and ballast combined...
The only time I would think about using a "dedicated" 3 point ballast weight would be in very close quarters and using the loader, or such on a construction site and most of your work is with the loader per say...
   / Loaded tires vs wheel weights #13
I, too, have no dedicated weight; just use my box blade for the most part. And I have water and antifreeze in my rear tires for ballast, but agree with Cowboydoc that the wheel weights would be my first choice; easier to add or reduce weight, easier to fix flats, etc. I went with the liquid ballast for two reasons: (1) Kubota does not show to have wheel weights for my model and I didn't want to build my own, and (2) less cost.
Bird
   / Loaded tires vs wheel weights #14
In general the most efficient use of you money is with the lightest possible combination. I let people run the tractors knowing with a fixed cost of the options after using the unit. Many people leave them light, some add on the weight after, most stay light.
   / Loaded tires vs wheel weights #15
Terry -
No matter what my primary chore at hand is, I wind up using my FEL virtually every time I take the tractor out, so rear weight is a must. I leave my box blade on most of the time, since it is the second handiest tool I have, plus it is fairly heavy and compact. The only time I take it off is to use my rotary cutter, which is even heavier.
My rear tires are also loaded, mostly 'cuz they came that way. I still have 600 pounds of lead I was going to use for wheel weights, but just haven't had enough need to pursue it.
   / Loaded tires vs wheel weights #16
Well... I guess I got enough reasonable answers to that question. /w3tcompact/icons/smile.gif
I suppose I'm the direct opposite to your situations. I have no need for a box blade and only have the FEL on about 25% of the time. Dang thing gets in the way. Most of my usage is in finish mowing, bushhogging, or tilling/plowing - pretty much in that order. I have just purchased a rear blade and have just began to learn how to use it. It does not provide enough ballast to offset a loaded FEL. So, for my application, a ballast box helps when moving a lot of materials.
So, I guess the best way to view it is that you have to look at your particular needs and equip your tractor accordingly.
Terry
   / Loaded tires vs wheel weights #17
<font color=blue>I guess the best way to view it is that you have to look at your particular needs and equip your tractor accordingly</font color=blue>
Now that's a fact, for sure.
Bird
   / Loaded tires vs wheel weights #18
James,
Looks as though the esteemed panel members have provided insight to your original post. /w3tcompact/icons/cool.gif
Terry
I have now decided to go with wheel weights. I believe they are the most versatile and leaves your 3pt hitch open for other attachments. Thank you everyone for your opinions.
   / Loaded tires vs wheel weights #20
Terry,
The only reason I wouldn't use one is because 90% of the time I've got something attached to the front and the backend. If I don't have a pounder, digger, backhoe, etc. on the back I put my box blade on the back for counter weight. If I didn't have all the other stuff to put on or need it then yes I would consider it.
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
