Loader chain hooks
   / Loader chain hooks #11
</font><font color="blue" class="small">( Hmmm...
Interesting observation...
Could you eloborate more on your statement, please?
> Doing so the bucket can be driven against its roll-back mechanical
> stop thus preventing reverse stress loading of the hydraulics.
Especially the "reverse stress loading of the hydraulics"?
)</font>
The torque of the tractor applied to a hydraulic
cylinder can exceed the design pressure of the system.
This is particularly true of impact loads where the
pressure relief valve may not be able to vent
sufficient fluid volume quickly enough to protect
system components.
A safer approach when pulling/pushing with a
loader bucket where the generated force is applied
rotationally to the bucket (eg: via chain) is to rotate
the bucket to either of its mechanical stops. Doing so
the force applied is seen by the mechanical stop rather
than transmitted to a hydraulic cylinder.
The above scenario is similar to the caution against
applying full horizontal torque of the tractor to a
bucket edge situated at a vertical 90*.
   / Loader chain hooks #12
</font><font color="blue" class="small">( Sorry Uhmgawa,
But you lost me a bit too, I have read and re-read your explanation...
And understand your "reverse stress loading" statement. Although when working a setup like Flusher's example the bucket is useful to provide vertical alignment/support of the sample lift.)</font>
That scenario isn't as much of a concern as the load is
fixed and not impact-applied. Ie: you either lift the load
or the relief valve vents. In this case the loader/hydraulic
system is able to protect itself per design.
As a contrived example to the contrary for the same scenario,
if you were to strike the bottom of the wall on the foundation
while the tractor was traveling horizontally you could
impact load the hydraulic system beyond its design limit.
</font><font color="blue" class="small">( But, why would 4WD CG be different than 2WD?)</font>
Operating in 4WD the front axle can generate sufficient
torque to lift the rear end of the tractor. This is also the
reason chains should be routed around the back of a loader
bucket and exit under the bucket, with the bucket positioned
as low as possible. Attaching a chain directly to the top of a
bucket creates greater mechanical advantage to lift the rear
end as well as the ability to do so by increasing traction of the
front tires. Chains routed via the bucket bottom are also
marginally safer in the case of breakage.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2009 Kenworth T800 Tri-Axle Day Cab Wet Kit Truck Tractor (A52377)
2009 Kenworth T800...
2013 F-550 Bucket Truck (A55218)
2013 F-550 Bucket...
40' CONTAINER (A51244)
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
Kubota ZG327 (A50120)
