loader control
/ loader control #2
Welcome to TBN
What is the problem with the valve? Only things that can be repaired on a spool valve is a leaking seal or faulty relief valve. If spool is leaking internally complete valve assembly must be replaced to correct problem.
/ loader control #3
Go to
https://mahindrausa.com/#
Have your tractor serial number at hand.
Go to the menu item "Owner."
I do not have a Mahindra but was told with a serial number you get access to more stuff than a regular guy can.
I am with Tx Jim in saying not much can go wrong with the FEL valve body itself. If yours has a joystick, some are cable operated to the valve and things come loose causing operational problems.
Dave M7040
iDrive TDS-2010H...
2005 Ford F-250 Utility Truck, VIN # 1FDSF20P95EA36128 (A61165)
2005 Ford F-250...
2007 Volvo VNM T/A Day Cab Truck Tractor (A61568)
2007 Volvo VNM T/A...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
UNUSED 44" MINI PLATE GRABBER (A62130)
UNUSED 44" MINI...
