Loader curled up or down for storage?
   / Loader curled up or down for storage? #11
Left the snowblower with the chrome out by accident one year and ruined the cheap tie rod cylinder. The tractors always get sucked in. I've got a drain hole in my Kubota bucket, its often plugged but will still slowly let the water out.
   / Loader curled up or down for storage? #12
In the Navy on and near Salt Water we wiped down all exposed cylinders with the same hydraulic fluid used in that system. Never saw rust on any cylinder. I don't know if that would be a problem when you are not near salt water. Never saw rust on any exposed cylinder on the farm in WI and MN either and they were never wiped down nor did we worry about if they were exposed or not. Rust in buckets and dump trailers due to standing water was the real worry.
   / Loader curled up or down for storage? #13
Mine used to have a shed to park in but now unless i make a spot in the barn it stays outside.
I tilt the seat up and usually try to angle the bucket so it will shed water. (not always flat when i park it on my hilly ground.)
   / Loader curled up or down for storage? #14
Hard chrome is porous. It will retain lube in these micropores but over time in moist areas they will rust. Here is advice for farmers from Louisiana State Extension Services. The tend to have a rather moist climate down there.
The solution to this problem is to prevent rust and pitting. There are three ways to accomplish this, and it is possible to use more than one of these approaches simultaneously. The best way to avoid corrosion and pitting of the cylinder rods is to store the implement with the cylinder rods retracted. If the rods are retracted, the sensitive plated surface of the rod will be inside the cylinder, immersed in hydraulic fluid and thus fully protected. Unfortunately, it is not always possible to store equipment with the cylinders retracted. In some cases, the cylinders must be extended to unhitch an implement or must be extended to park the equipment. Another way to reduce the chance of corrosion is to park equipment with hydraulic cylinders inside a building where the cylinders are protected. This will significantly reduce corrosion and pitting, although humidity and condensation can still occur in some storage sheds. A final method of protecting cylinders is somewhat less effective but can be used in all situations. The exposed cylinder rods can be coated with heavy grease whenever the equipment will not be used for a few weeks or longer (Figure 2). The grease should be as heavy and sticky (tacky) as possible. Wheel bearing grease is better for this purpose than general chassis grease because it tends to be tackier. A heavy coat of grease will provide several months of protection, but for a machine used only one season a year, it may be necessary to renew the grease every three to four months.
   / Loader curled up or down for storage? #15
I dont know where you heard that chrome is pourous but chromium is about the best anti-oxident around for metal. I have seen cylinder rods left exposed and laid up against a tree for 30 years and not a speck of rust on them. This was not on a ocean beachfront so I dont know how well they would do in salt from northern road, but I will put money on cylinder rods outlasting the attachment it is on if both are neglected after exposure to salt and chemical. As long as the chromium coating is not scratched or chipped so that the underlying metal is exposed it will last indefinitely when only exposed to fresh water and air. Pitting occurs on chromium and chromium alloys when they are contaminated by iron dust or chips but usually can be removed with no damage to the chrome with phosphoric acid if not left for long periods. We have that problem on construction sites when stainless steel pipe gets carbon steel dust on it from grinding other material nearby or power brushing it with a carbon steel brush. Application of phosphoric acid (Weedac is a brand name I have used) will eat the carbon steel and leave nothing but stainless or chromium behind nice and shiny. It may take more than one application left overnight to remove heavy amounts. It will turn the carbon steel black until it is all gone then just wash with water/baking soda mix to remove/neutralize the acid.
   / Loader curled up or down for storage? #16
Thanks for the reminder to put my bucket under cover now that it isn't winter anymore. Still have the bale forks on...you can even move a small tree out of the way with the bale forks!
   / Loader curled up or down for storage? #17
Would it not be cheaper to replace a cylinder than a rusted out bucket ?
Fred H.
   / Loader curled up or down for storage? #18
I had to replace a very small cylinder on a snow blower attachment. Used one was a hundred bucks.
iDrive TDS-2010H...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2020 Deere 50G (A53317)
2020 Deere 50G...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
