Loader Problem
/ Loader Problem #1
Shirley York
Cookeville, TN
John Deere
Bush Hog Loader on John Deere tractor. Loader stopped working but 3-point hitch works fine. Checked lines, pressure, valves - no luck. Was working fine. Now will just barely pick up the bucket. Have had all local mechanics try to find the problem, but no luck.
/ Loader Problem #2
If there are any quick disconnects involved in the loader control valve plumbing then check them to be sure they're seated properly
/ Loader Problem #4
What Jim said.
Also, the pressure relief valve could be stuck open. Sometimes a small piece of trash will cause it to hang up. (I saw this happen on a brand new industrial TLB, and it was a loose drop of solder) If all the QC's are ok, disassemble and clean the relief valve.
2023 John Deere 8R 340 Tractor (A63111)
2023 John Deere 8R...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2004 John Deere 4720 (A60462)
2004 John Deere...
1067 (A63291)
1067 (A63291)
KING 18 SHANK 3 BAR CHISEL PLOW (A63291)
KING 18 SHANK 3...
Pat's QH and hydraulic top-link.
Pat's QH and...
