Loader Problem
/ Loader Problem #1
Shirley York
Cookeville, TN
John Deere
Bush Hog Loader on John Deere tractor. Loader stopped working but 3-point hitch works fine. Checked lines, pressure, valves - no luck. Was working fine. Now will just barely pick up the bucket. Have had all local mechanics try to find the problem, but no luck.
/ Loader Problem #2
If there are any quick disconnects involved in the loader control valve plumbing then check them to be sure they're seated properly
/ Loader Problem #4
What Jim said.
Also, the pressure relief valve could be stuck open. Sometimes a small piece of trash will cause it to hang up. (I saw this happen on a brand new industrial TLB, and it was a loose drop of solder) If all the QC's are ok, disassemble and clean the relief valve.
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2017 Case CX145D (A60462)
2017 Case CX145D...
John Deere 1025R (A62177)
John Deere 1025R...
26120 (A56859)
26120 (A56859)
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2015 GMC 1500 Sierra Crew Cab Pickup Truck (A61573)
2015 GMC 1500...
