CBCGC1715
- Joined
- Mar 10, 2019
- Messages
- 52
- Tractor
- MF GC1715
I have a question if the loader on my new GC1715. Will it sag when resting for a period of time?
Thanks for the info. It makes sense to not have the loader suspended, but I just wasn't sure if the cylinders would allow fluids to flow when in the off position.There was a big thread on this topic not too long ago that had people defending their positions. The general consensus is that it SHOULD not, but there is no guarantee it WILL not.
It's also good practice to make sure you lower it to the ground when shutting the machine off and leaving it unattended.
I lower both the grapple & rear blade to the ground. Takes the pressure off the seals and no danger of somebody getting hurt if either should sag or be accidentally lowered while playing on great grandpa's tractor.
What he said. More important than the parking brake, unless you have no implements attached. :laughing:
I have a brand new (well, 20 months) MF 1754 and the loader valve and the cylinders will both allow sag overnight. The way i know the cyliders allow sag is i installed a hydraulic (high pressure) ball valve to be able to lock my loader in a raised (and potentially dangerous) position. Even with the ball valve closed, my loader will sag. I interpret this to mean the cylinders themselves are leaking a small amount of oil from the ”raise side of the cylinder piston to the “lower”side of the piston.
For comparison, I used to have a 1954 Case 400 tractor. (about 45 HP, but these horses were a bit bigger than the 54 horses Massey put under my new hood)
The 3-point (Eagle Hitch, to be more accurate) would hold a darn heavy, 9 foot wide, 4 foot high home made back blade (for snow) up all summer. Never sagged an inch.
So my experience has been some cylinders hold, some dont
It has to, there is no other place for it to go unless it is leaking to the outside.Do you suppose that the bypassed oil (if that is whats occurring) does in fact pressurize the other side of the piston and THEN leaks thru the spool valve, and back to the resevoir?
There was a big thread on this topic not too long ago that had people defending their positions. .
