Local dealership closed
   / Local dealership closed #11
Trailers may be 'cheap' in the $1500-$2000 range, but if you don't have a vehicle capable of pulling it, well .....
All color dealers are 40-80 miles from me. Grocery stores and most other stores are 20-30. Distance is relative.
   / Local dealership closed #12
This isn't happening to tractor dealership even motorcycles dealers are facing it also...the mall look.
   / Local dealership closed #13
I understand the impulse to jump to JD, but if you do be very sure you can count on the dealer sticking around. I like the trailer idea...
30 years ago when I had a Green Thing parts and some service were (long) walking distance. JD yanked their franchise. OK, a 20-mile drive to a quality dealer... I can handle that. JD yanked their franchise. Ouch. 90-mile drive to a decent dealer, and at least it's near the fishing cabin, so I can handle that. You guessed it... JD yanked _their_ franchise. At that point it was a ferry ride and an hour drive to a big dealer. I have no idea if they still have their franchise - did that once, never again.
Went orange. A bit of a pain (the local dealer leaves something to be desired..) but there are two quality dealers worth the drive.
TLDR: based on history, you can't count on JD dealers sticking around...
my $.02,
Z.
Based on your own history... in your own little neck-of-the-woods.
I, on the other hand, live on a magical island where the JD dealership knows me by name and are a pleasure to deal with in all aspects. It is a 2 hour, one way, trip to visit them... but it would be at least the same for any of the other colour tractor dealerships.
To the OP: I agree with the advice about either getting a float (trailer) to transport your tractor/Z-turn to the dealership or pay for a remote visit. There's no need to ditch them if they're perfectly satisfactory to you.
   / Local dealership closed #14
Foozle - most of the JD dealers in your area are now owned by Ag-Pro. They bought up 84 dealers from TX to SC to Ohio. If big is better, then you have that. If it were me I would keep all you have and get it serviced as needed at a much lower cost than you will have if you decide to jump colors.
Thanks for all the advice! I probably did blow things more out of proportion than needed to be. I guess it is just frustrating because you'd think Kubota would have had some sort of transition plan in place before forcing that dealer to close. There is also a Kubota construction dealer nearby that has been begging to become a full line dealer, but for some reason Kubota isn't letting them. I guess they are very picky about granting dealerships. I can check with JD/Ag Pro, but not sure they will service Kubotas -- if so, that would solve it.
Probably the trailer idea is the best one, but the only downside is that I would lose my excuse for not letting my son-in-law borrow my equipment! :)
   / Local dealership closed #16
Maybe you could "coerce" the SIL into buying the trailer???
SDT
   / Local dealership closed #17
most any capable (truck or diesel), should be capable of working on your tractor,
95% of maintenance is changing fluids and filters, can checking air in tires,
usually changing oil in a tractor is simple and most filters are easy accessible, one may have get a bit dirty but for a tractor owner that should not be a problem to one,
unless one needs injector work or an overhaul or clutch replaced, and that should not happen in the first 3000 to 5000 hours, and I would venture to guess you don't put that many hours on the tractor, so my guess is you will not come to that point in 10 to 20 years, maybe longer, we farmed for the last 40 years, I have two 4020 tractors 1970, and 71, and ran in the fields all summer long, for over 49 years, they both have about 10,000+ hours on them that was running them up to 8 to 12 hrs a day many a summer day, one should be able to do your normal maintenance without a dealer next door, I think my one tractor has been in the dealership one time in it life, and they did not fix it right, I have overhauled both tractors and clutches, (split them) about 6000 hours on both of them, for the last 49 years done the maintenance and repairs,
IMO you should be fine for 99% of the time,
and besides at the dealership rates they charge an hour, even if your tool poor currently, it wouldn't take to many trips to pay for a nice complete set of tools.
   / Local dealership closed #19
It's often more about the actual mechanic that works on your stuff anyway. although without doubt, a dealership has more resources available for their stuff than someone elses. Especially new stuff.
   / Local dealership closed #20
Since the SIL may end up with your equipment one day anyway he might "Need" to take the opportunity to maintain it and care for it himself or trucking it on his trailer you can also use for other needs. I have two trailers that I've maintained for a SIL and two nephews for some years.
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
TANK MANIFOLD (A58214)
1454 (A57192)
1454 (A57192)
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
