location of L275 temp sender
   / location of L275 temp sender #1
tsterkel
Bronze Member
North Texas
2202 Kubota
Temp guage not working. Got the Temp sensor, and could not find where it goes. The manual does not say. Could someone tell me, in simple directions, where to find this sensor?
thanks!
   / location of L275 temp sender #2
usually on right rear corner of head.
   / location of L275 temp sender #3
also, check right side rear on the engin block, look for the wire coming from it.
   / location of L275 temp sender #4
You know how people say to go with your first impression? I may be all wet but something tells me the temp sender on these older kubotas is a capillary tube to the gauge. If this is right, the "wire" isn't a wire but a jacketed flexible tube - looks like miniature romex. It's a complete one-piece assembly with the gauge. Probably expensive now - and maybe has been superceded by an electronic one?
As always, prompt cheerful refund if info is bogus. Let me know if you'll be claiming the refund. /forums/images/graemlins/smile.gif Take care, Dick B
14ft Flatbed Truck Body (A48081)
14ft Flatbed Truck...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A50459)
KNOW BEFORE YOU...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A48836)
2013 International...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2021 Ford Econoline Van, VIN # 1FDWE3FN7MDC03249 (A48836)
2021 Ford...
New/Unused 7ft 20 Drawer Work Bench (A48837)
New/Unused 7ft 20...
