Glen,
I don't think it is a question of whether this particular lock valve would work to lock a cylinder in place, but more a question of what is going to operate the pilot valves within the lock valve itself.
My take on this particular lock valve is that it requires a seperate pilot pressure source, as compared to other type lock valves which use the actual pressure that comes from the control valve that is used to operate the cylinder itself.
In otherwords, the lock valve that we see mounted on CCM's cylinders or on the TCC cylinders are the type that don't need an seperate pilot pressure applied. Those lock valves have four connecting points for hydraulic hoses. Two that come from the control valve and two that go from the lock valve to the cylinder being controlled.
So the question is does that lock valve you ordered from the
Surplus Center have four or five places to hook hoses to? IF it only has four than it will probably work. If it has five [or maybe six] then it is designed to be used in a system that has a seperate source of hydraulic pressure to unlock lock valves...and it probably will not work, at least not without some creative plumbing on your part.
Like I said, this is my take on that valve without seeing any specs, drawings or physical representations of the internals of this lock valve.
Use to hold double acting cylinders in place until pilot pressure “unlocks” circuit. is what got me worried that this particular lock valve required a pilot pressure independent of the working pressure that is sent to the cylinder.
I hope I am wrong as I would like to buy a couple of these same lock valves if they would work the same as CCM's do.
Let us know how this turns out.
