Locknut on upper link of 3ph?
   / Locknut on upper link of 3ph? #1
smokedtires
Bronze Member
Lysander NY
I noticed that the locknut on the upper arm has a small rod tack welded to it. Can you tell me why it's there and if I need to on the nut? /forums/images/graemlins/confused.gif
Thanks !
   / Locknut on upper link of 3ph? #2
If we are talking about the same thing, mine has 2 rods welded to it, one on each side. I just assumed they are there for hand tightening/loosening when I make adjustments in the top link length instead of having to get a wrench. At least that is what I use them for. I hit it with the side of a gloved hand to loosen and the same to tighten.
There is a rod that passes through the adjusting shaft in the middle, then there is a locking nut on the threads near the rear of the upper link that has a small rod (~2") tack welded directly to the nut on one of the flatted sides. It seems like the rod would get in the way of a wrench when trying to lock it tight.
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2022 KMC 21-37-HD LOT NUMBER 177 (A53084)
2022 KMC 21-37-HD...
2012 FORD 4 DOOR TAURUS SEDAN (A52576)
2012 FORD 4 DOOR...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
