Locknut on upper link of 3ph?
   / Locknut on upper link of 3ph? #1
smokedtires
Lysander NY
I noticed that the locknut on the upper arm has a small rod tack welded to it. Can you tell me why it's there and if I need to on the nut? /forums/images/graemlins/confused.gif
Thanks !
   / Locknut on upper link of 3ph? #2
If we are talking about the same thing, mine has 2 rods welded to it, one on each side. I just assumed they are there for hand tightening/loosening when I make adjustments in the top link length instead of having to get a wrench. At least that is what I use them for. I hit it with the side of a gloved hand to loosen and the same to tighten.
There is a rod that passes through the adjusting shaft in the middle, then there is a locking nut on the threads near the rear of the upper link that has a small rod (~2") tack welded directly to the nut on one of the flatted sides. It seems like the rod would get in the way of a wrench when trying to lock it tight.
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
23222 (A50323)
23222 (A50323)
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A52748)
COOPER LIGHTING...
