jack707
Veteran Member
I am having frustrations with the Ariens log splitter I bought. So I am wondering how reliable the splinters for the pto are and what brand is good.
So what your telling me it's a lot of upgrades I have to buy. It would be cheaper with another gas engine.IF you want any speed, you need a decent sized pump, bigger hoses, valves with decent flow rating along with a decent port size in the cyl...
You see, it's all engineered to work together...
SR
You wouldn't have to upgrade anything except the pump. You wouldn't even have to do that, but your tractor hydraulics are low GPM. Unless you have multiple tractors I wouldn't use it for a splitter.So what your telling me it's a lot of upgrades I have to buy. It would be cheaper with another gas engine.
okay I'm trying to understand this now I need the pump for the PTO to power the splitter....right?You wouldn't have to upgrade anything except the pump. You wouldn't even have to do that, but your tractor hydraulics are low GPM. Unless you have multiple tractors I wouldn't use it for a splitter.
If the flow goes up (from a bigger pump) and you want to use that flow, you DO need more than just a pump...You wouldn't have to upgrade anything except the pump. You wouldn't even have to do that, but your tractor hydraulics are low GPM. Unless you have multiple tractors I wouldn't use it for a splitter.
The implements on my CTL tell a different story. I have varying flow rates exceeding 20 GPM and on every flow rate the grapple cycles faster and it's plumed with like 1/2 od lines. I can't hear the hydraulics straining so it's not adding that much resistance. I know it's not hardly apples to apples, but most wood splitters I've seen have 5/8 od hoses.If the flow goes up (from a bigger pump) and you want to use that flow, you DO need more than just a pump... I guess if you don't mind sloooow, then it won't matter much, the pump will just make more heat with the restricted flow... No doubt, another motor to replace the problem motor is going to be the cheapest way out....OR fix the problem motor. SR
Since I bought the Ariens I had trouble with it. Just picked it up they put a new carb. on it it ran then stopped and the carbs. you can't adjust .The Ariens splitters are not that great -- in fact, other than paint color they look like many of the MTD/Troy-Bult spinoffs, so I suspect they are one of them in disguise. When I was shopping for splitters, the Dirty Hand Tools models, the Countyline Models at TSC, and the NorthStar models at Northern Tool were the best ones that had their own unique design/manufacturing. Everybody else was a MTD/Troy-Bilt variation. So maybe you just need to find a better gas-powered splitter.
Just make sure you get a PTO pump type, not one you plan to run off the tractor hydraulics. They will run off the tractor system, but slow....most tractors don't have the volume or pressure needed to run a splitter. I went that route originally, but was disappointed by how slow it was, plus I didn't like it tying up my tractor.....like a big scorpion tail out the back. So I used the 3pt splitter as the guts of a stand alone version.....added a 16gpm 2 stage pump, tank, wheels, and a Honda GX240 to run the pump.
Can someone school me on the advantages of a splitter running off the PTO? I don't get it. Although I'm new to tractors, I split about 15 cord a year and don't see the sense of 1) tying up the 3 pt, and 2) running a big Diesel engine instead of a little stand alone gas engine.
