log splitter attachment. Yes or no
   / log splitter attachment. Yes or no #1
jester7891
NJ-PA border on the Deleware
Kubota B7610
I know this question has come up before so if the answer exists elsewhere, please send me there. I have a 24 horsepower Kubota B7610 and have a lot of wood to split. I am trying to decide if I want to buy a log splitter as an attachment or get a log splitter that has its own engine. Obviously using either the hydraulics or the PTO saves me from having to deal with another engine. I am not really concerned about running up hours on my tractor as I do not plan on selling it anytime soon so that is not a problem for me. Additionally, I would assume using a log splitter attachment would be considered "easy time" for the tractor. I am guessing that I would need to use the log split at most 50 hours between now and the spring. What are the advantages/disadvantages of each? Once again, thanks for your input and suggestions.
Jester
   / log splitter attachment. Yes or no #2
Search the word "logsplitter"
   / log splitter attachment. Yes or no #3
In short:
3Pt Logsplitter is slower, and ties up your tractor. Cheaper and one less engine to maintain.
Standalone is usually faster (good ones are significantly faster), you can split without your tractor, or use your tractor for hauling the rounds or split pieces. More expensive.
I went with an electric logsplitter: RamSplitter. 16 ton - the biggest I could get and still run on standard 110VAC. Most of my splitting is done right near the house anyway. Nice and quiet, no gas engine to maintain. When I do want to split in the woods, I have to bring my generator with me. It took me a while to find one that was powerful enough for my needs. There are several electric ones out there that are from 3 to 6 ton... just too small / light duty for my needs.
   / log splitter attachment. Yes or no #4
I have the Ramsplitter 16ton electric too and easily split 4 cords this summer. Up to 20in diameter if I split the outsides off first.
   / log splitter attachment. Yes or no #5
It comes down to expectations. No doubt, dedicated self-contained splitters are faster and more powerful...especially compared to small tractor hydraulics. If you're looking for "production" splitting, choose self-contained. There are lots of reasons to go self-contained. Two-stage pumps for faster cycle times, and larger cylinders/longer stroke for more force and longer logs.
If you elect to use your tractor hydraulics, you need to know your hydraulic system. GPM and how system is plumbed. For example, based on my GPM, I chose a 3-point splitter with a smaller cylinder...in order to have acceptable (to me) cycle times (15 seconds @ 3K RPM). The smaller cylinder has an 18" stroke, which limits me to 20" logs...again OK for me, my woodstove only takes 20" logs. My splitter is rated at 16 tons, and won't split everything. I have to finess the really gnarly crotch wood, and even then sometimes make kindling.
As for plumbing, I have power-beyond, and used that part of my backhoe connections. In my system, the BH is first, then the FEL, then the 3PT. Log splitter control valves expect high (pump) pressure on the inlet side, and low pressure on the outlet (tank) side (my valve is rated at 500# outlet). I use my FEL to move wood, and adjust my 3PT to the ground for big logs...BUT...not while splitter is hydraulically connected. In power-beyond systems, using downstream controls can cause back pressure to the pump relief valve, which can exceed the outlet rating of upstream splitter valve (my system). Know the kind of system you have, and where you intend to insert the splitter...
Finally, I bought my splitter a while back on eBay for less than I could build one. If I had to pay Ramsplitter's current 3PT price, I would own a stand-alone...
   / log splitter attachment. Yes or no #6
I have a 22 HP Kubota. I have been using the 3pt log splitter from Northern Tools, and it works quite well. It will split 24 in logs. Easy on and off. I have the hoses coming to the back that I connect together when not in use. I use QD's on the lines. You can raise the log splitter to a good working level. You can take it in the woods and cut and split and if you pull a trailer behind the log splitter, you can haul it out. There really are no disadvantages, You probably only use it for awhile, and it sits around the rest of the time. Older people like myself don't need to work fast anyway. The speed of the engine will dictate your splitting time. If you wanted fast cycles, you can add a PTO hydraulic pump.
   / log splitter attachment. Yes or no #7
I use a 3pt slitter on my 7500. Works well - no power problems at all - but it is not the fastest thing in the world. A standalone would probably work twice as fast. I split about 12 face cords per year which takes me about 8 hours. If you are really talking 50 hours of splitting, I would suggest that you go with the standalone version. If you really don't want a separate engine, get 3 pt model with a pto pump - it will be as fast as a standalone but won't have an engine. Ramsplitter has these models (see John's link above).
   / log splitter attachment. Yes or no #8
Some things just go together......... like pizza and beer.
Or....... splitters and two stage hydraulic pumps, something you won't get with a three point splitter.
   / log splitter attachment. Yes or no #9
I owned a 3-point splitter for a while. Now I've got a towed "stand-alone" type.
The #1 reason why I DIDN'T like the 3-point model? When I needed to move it, I had to fire up a tractor, hitch up the splitter, move it, then un-do the entire process. Towed model, I just grab the hitch with both hands and move it where ever I want it.
3-point model means tractor is for the most part, unavailable for any other duties while splitting. Sorta crowded with the tractor so close to where the work is going on. I'd just as soon wear out a small engine as opposed to piling up hours on a much more expensive tractor. All things equal, the Honda engine on my splitter is cheaper to fuel for the same running time as a tractor @ a fast idle.
BTDT, had both, keeping the towed self powered splitter.
   / log splitter attachment. Yes or no #10
I have a 3 point splitter on a JD 790 and I am very happy with it. I split 30 or so cords per year and it will split as fast as I can work. I use a 4 way wedge some of the time and a single for the tough pieces. Given my hydraulic pressure I am getting a little over 20 tons with a 24" stroke. I have never timed the cycle though. The maint was really the deciding factor for me. I have several pieces of equipment that have their own engines and when they go they will be replaced with a PTO shaft if possible.
John Deere 72" Bucket (A47307)
John Deere 72"...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2011 Ford F-150 Pickup Truck (A46684)
2011 Ford F-150...
2021 CLUB CAR  CARRYALL 1700 (A45046)
2021 CLUB CAR...
2018 Ford Focus Hatchback (A46684)
2018 Ford Focus...
New Holland 217 PTO Manure Spreader - LOCATED NEAR REYNOLDS, IL (A49339)
New Holland 217...
