Log splitter buying ?
   / Log splitter buying ? #51
You actually wash and rinse your logs?? That's so cool. I've never heard of that. But then, I've never heard of measuring the cuts either. Yep, my woodpile is not pretty. :)
No, I do not wash & rinse my logs. "Wash, rinse, repeat." is just a colloquialism for repeating the process.
With regard to measuring the cuts... A couple of thoughts.
First, we have two different sized stoves. The larger ones can take up to 22", but for a lot of reasons we prefer 18"-20" logs. There is also a small
stove in our kitchen that will only take 14" lengths. So it is a lot easier to measure the cuts to ensure that we have enough wood for the small stove
as well, rather than relying on the butt ends.
Second, I knew that I wanted a sawbuck. Many advantages. First they support the logs very well & you have virtually no binding or kickback.
Second, the sawbuck keeps the wood well above the ground and saves on saw chains. Third, the sawbuck can be made at a height that works well with
rolling the logs off of the grapple. Sure you can cut the logs on the grapple, but you are either limited to one at a time on the grapple, or you have to
focus on a single log to cut, and avoid the others in the bundle. Also, have to avoid the steel on steel contact between the grapple & saw. If I get too close
to the sawbuck, I am just nicking wood. Finally, since I knew that I wanted to use a sawbuck, it only made sense to have the compartments double as
a rough measuring device. Neater woodpiles, more consistent log lengths and with two different sized stoves, two differently configured sawbucks makes
it easy.
The sawbucks are very handy, a great back saver, add to the safety of the operation and one of the simplest & best additions we have made to our firewood cutting.
It is not for everyone, but that is how we approached it.
   / Log splitter buying ? #52
OK, since you asked.
That's very cool!!!! Does it have a winch on it as well??? Or maybe you already talked about that and I missed it??
I'm always looking for something to build. I might build one of those. Are the 3pt arms attached low on the skidder so you can get a lot of log height?? My timber is very steep and rough. I'd want the tractor end of the log to be as high as practical. Any more pics of the skidder would be appreciated. I'll do a search as well. Thanks for the pic.
   / Log splitter buying ? #53
Agree with all of this, though I have gotten pretty good at "tuning" a chain in a few minutes to keep it cutting very well. I prolly have 5 or more chains for each of 4 saws I keep busy on my wood cutting chores. I put up prox 20 cord a year from my own property.
That's somewhere around what I cut. I cut for my shop stove and 2 Son's shop stoves. I try to block a huge pile and let it cure for a season before blocking. We're in the process of splitting up that pile now. Then thru the Winter I'll harvest more logs and replenish the block pile. If possible I block from the Grapple.
20141010_112307 (1280x720) (1280x720).jpg20141010_120216 (1280x720) (1280x720).jpg
   / Log splitter buying ? #54
I went to tsc Saturday and made the purchase. The 22 ton unit was on sale for $899 so I got it. Only time will tell if I. Like it or not. Thanks for all the help in making me choose a stand alone unit. Thanks
:thumbsup: Thanks for letting us know what you decided. If you didn't get the table with it you will probably want one. I made mine.
   / Log splitter buying ? #55
I also like a table around the end of the beam to catch the splits. Saves having to pick them up off the ground.
   / Log splitter buying ? #56
Menards had the Dirty Hand Tools 27 ton splitter on Friday for $699. I took the ad to Lowe's because they are closer & they matched the price + 18 months 0% interest!
   / Log splitter buying ? #57
Somewhat surprised that no one mentioned the split fire splitter. I have a Split Fire 255 with the wedge on the cylinder and a bolster on each end allowing one to split in both directions, both out and back. It's amazingly fast and it came with a hydrolac log lifter so no wrestling large rounds up to the splitter table.
This year instead of stacking firewood I'm bagging it in 'Dino' bags. (Google Dino bags)
Each bag holds about 2/3 of a cord and using the pallet forks on my FEL suspend the open bag next to the splitter, then split, toss, and done. I then place the full bags on pallets and with the forks place the bags in the shed. This system takes up a little more storage space however, the labor savings are well worth the minor loss of square footage.
   / Log splitter buying ? #58
That's a good idea to have an end table if you have a fixed wedge and your split wood comes off the end. With the wedge on the ram, like the splitter the op and I have, the split wood comes off the side. I position the chunk to be split so the finish piece comes off on my side which I throw on the pile and the big piece falls onto the table where it is easy to grab for the next split. No picking wood off the ground.
   / Log splitter buying ? #59
We had a stake body dump that held about 2.5 cords of splits. With as many as 3 guys on the landing, we did two of these in an 8 hr day as many as 6 times a week if we were cutting a big plot. There was very little money in making firewood as opposed to mill stems back then. A split cord went from $60-$75. We'd make trips to the Cape Cod where they were getting almost double for the stuff. (Can't cross state lines with wood anymore around here). Firewood making just beat stuff up and was rather labor intensive in comparison to other types of logging.
   / Log splitter buying ? #60
They do look like time savers but what will be interesting John with these, is to see how well wood such as red oak seasons in them.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2024 KMC 7406 (A53084)
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2016 FONTAINE 53FT SPREAD AXLE DROP DECK FLATBED TRAILER (A53426)
2016 FONTAINE 53FT...
