Log Splitter / Hydraulics ??
   / Log Splitter / Hydraulics ?? #11
<font color="blue">I thought open center was typical of most small tractors and closed center was typical of most larger tractors regardless of make? correct me if I'm wrong.
</font>
That was my impression as well. I have a "New Holland" hydraulics instruction book I bought on ebay. It "confirms" our impressions.
A closed system can offer higher performance, but can be more complicated.
   / Log Splitter / Hydraulics ?? #12
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Closed center typically means a JD tractor.. )</font>
Paul
Andy )</font>
All my big tractors are 1979 or older. Closed center is a newer idea, so you are probably right. It has more to do with age tho. John Deere used it a long, long time ago, while others just started using it a decade or so ago....
--->Paul
Did I mis-speak when I called it a "detent"?
I thought a detent was simply a hydraulic control lever? Does it mean more like it sticks open or has some other feature?
   / Log Splitter / Hydraulics ?? #14
Dentent is when the lever holds itself in either postion (lift or raise - can hold in one or both directions) until the overflow valve goes, then it releases itself back to center 'off' position.
For a log spliter, it is not legal to build one for sale commercially with detent in the splitting direction (what you do for yours is your business), but it is _very_ handy to have a detent in the return direction. Then you can be picking up the pieces, or getting the next log while the ram is traveling back to home position.
--->Paul
1748 (A58374)
1748 (A58374)
TANK MANIFOLD (A55745)
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
