Log Splitter Power question?????
   / Log Splitter Power question????? #1
Hiltz
Michigan
JD 790
Hey guys, I just bought a old homemade log splitter off Cragslist. Sort of a Rube Goldberg looking contraption but the guy said it worked. It was a really good deal so I took it home. It did work great until I blew a hose. Since all the hoses were cracking I replaced them all, emptied and cleaned the reservoir, and replaced a seal on the pump. I put in new hydraulic fluid and fired it up. It works even better now. I was wondering maybe some of you hydraulic guys might give me a ballpark figure of how many tons of force this splitter has. The specs are: the pump runs off my JD 790 PTO which has 24hp, the cylinder is 4 1/2" in diameter, 2" ram, 24" travel, all hoses and fittings are 1/2 inch. I dont know anything about the pump, it seems to be old. If pictures are needed I can post pictures. Thanks in advance.
   / Log Splitter Power question????? #2
The force will depend on the pressure setting of your splitter's relief valve. You would probably have to install a pressure gage to find out. If you know the pressure in PSI, then just multiply it by the area of the cylinder piston (15.9 in^2 for a 4.5 inch diameter cylinder) to get the extending force in pounds.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
