Log Splitter Stutters
/ Log Splitter Stutters #1
helpfulbook
Bronze Member
Adirondacks, NY
John Deere 4700 Woods Backhoe 750, 460 Loader, Woodmaxx SB-72
Hi Guys, I've been splitting a lot of firewood lately and I noticed the push arm on the splitter when it is retracting backwards stutters.
It only seems to do it after I'm splitting for a while and the machine gets warm.
Does anyone know what the reason may be?
Thank you,
George
/ Log Splitter Stutters #2
Easy one would be low fluid and lube the track.
Thank you, I have added fluid, just wasnt sure how much to put in and didnt want to over fill.
I will grease the track.
Thanks again,
George
/ Log Splitter Stutters #4
It should still have some in the reservoir with the ram fully extended but not overflowing when fully retracted.
/ Log Splitter Stutters #5
Check the fluid when it is warm/hot. It is amazing how much it expands when it heats up. If you overfill it while it is cold you can have quite a mess when it heats up DAMHIKT.
I don't know that I would grease the track. On mine that would just make a mess collecting dust and wood debris. If you use any lube it should probably be a dry lube.
Doug in SW IA
Yeah I can only see fluid at the bottom of the reservoir.
Doug in SW IA
I'll make sure when I check it when it is hot. I was afraid to open the cap when it was hot...LOL
Thinking it would act like a hot radiator.
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
UNUSED KUBOTA 12" PIN ON EXCAVATOR BKT (A62130)
UNUSED KUBOTA 12"...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
1980 Chevrolet C60 Dump Truck (A61165)
1980 Chevrolet C60...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2012 Volkswagen CC Sedan (A61569)
2012 Volkswagen CC...
