Logging cable?
   / Logging cable?
Charles Park said:
Is the idea to pull brush out of the ground by the roots? Or to just gather brush that has been already cut and haul it to a pile?
I want to pull them out by the roots to slow the rate they return. I ordered the 3/8" cat choker from Bailey's. It looks like the right tool for the job. I may keep an eye out for one with a longer cable. Or find someone to make one up for me.
   / Logging cable? #12
How is cable thickness rated for horsepower? I would like to use a cable but I do not want the dreaded "Snap"? I know the thinner the cable, the easier it is to handle but the maximum pull will be less.
I have 47hp tractor. What size cable choker would I use?
TIA.
   / Logging cable? #13
If you are lifting with the bucket or pto, anything with a working load limit comfortably excess of capacity.
I'm sure some of the more knowledgable people here would know how to calculate drawbar pull in pounds. I'd buy a large margin for that, as there's more oppty for dynamic loading (ie jerks). I really don't think jerking cable is a great idea....
I use grade 70 chain from Harbor freight.
   / Logging cable? #14
TIA.
I have 1/2" cable which is what my logger neighbors use on their skidders- these cables have mega pulling power-way more then I would ever need. There are also 3/4, 5/8 and 9/16"s sizes to. I will buy 3/4" from now on.
see http://www.slingchoker.com/pdf/WIREROPE.PDF
and Wire Rope - Woodlander Products
   / Logging cable? #15
good point. Basically, no one ever got upset by their cable NOT breaking. And from the sounds of it they are pretty deadly when they do. I'd be cautious and go large.
   / Logging cable?
I'll let you know if I manage to pull mine apart. I really don't believe it will be a problem. Larger cable is a PITA to work with.
   / Logging cable? #17
Correction-I meant too write I will buy 3/8" from now on. As Steve suggested it's more the strong enough and will be easier to work with.
Caterpillar 906M (A53317)
Caterpillar 906M...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
