Logging winch drive chain lube?
   / Logging winch drive chain lube? #11
In my opinion chainsaw bar oil is the wrong product for a snowblower chain. I go through a lot of chainsaw bar oil in both the winter and three season variety on my 65cc Husqvarna chainsaw.
The bar oil tank only lasts for two tanks of gas. It is used up very quickly as it isn't intended to adhere to the chain or bar; it just lubricates the high speed action.
The chainlube products are much stickier and adheres to the chain for a long time; at least that had been my experience.
   / Logging winch drive chain lube? #12
I'd agree... the chain saw bar oil is thick and sticky.. but not tacky.. the chain lube is more of a spray grease.. not a thick oil.
soundguy
   / Logging winch drive chain lube? #14
I purchased a Farmi last month and the lube spec's are after every 50 working hours grease the drum chain lightly with spray type hardening chain grease (not oil). Wipe off excessive grease.
   / Logging winch drive chain lube? #15
Thanks for the confirmation hunchback. That Farmi must be a great tool/implement for skidding trees huh?
   / Logging winch drive chain lube? #16
probably several different names for a tacky lube. in the nw we call it gear dope. comes in a spray can and is totally sticky. Use for chains and gears. Loggers and pile drivers use it for open teeth and chains on cranes and yarders.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2016 VOLVO VHD TRI-AXLE DUMP TRUCK (A51222)
2016 VOLVO VHD...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2018 FABRIQUE 20FT TRAILER (A51222)
2018 FABRIQUE 20FT...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
