Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
Check out a new video! Scott explains some of the common welding symbols you see today in the welding world. Subscribe to our channel for more welding related videos.
Checkout www.freeweldingforum.com for welding tips, tricks, advice, and FUN!
Gotta see this, Scott tries to weld as long as he can with the LONGEVITY MIGWELD 100 to test the unit's duty cycle. This video is less on technique and more on understanding the duty cycle and seeing if we have overstated it or understated it.
Take a look at the welder on our website at www.longevity-inc.com
Also do not forget to join our welding forum as well at www,freeweldingforum.com
Hey Everyone check out this new video! Scott shows off the skip welds using a LONGEVITY Migweld 100 - flux core mig welder. Technique is explained. Subscribe to our welding forum at www.freeweldingforum.com
The Migweld 100 is currently at $150.00 and comes with flux wire.
Check out how Scott uses the LONGEVITY TIGWELD 200 EX to weld aluminum using pulse on a multipass lap joint. Take a look at his advice and technique, timing, and preparation on the weld.
Gotta see our newest video! Scott shows off the super affordable LONGEVITY MIGWELD 100, which utilizes flux core wire and allows anyone to weld at 110 power.
Hey everyone, Scott shows how to weld a corner joint using a flux core mig welder using flux welding wire, which does not require shielding gas.
Subscribe to our welding channel.
For all of your flux core wire and welding needs go to www.longevity-inc.com
In this Longevity Learning Lab video, Scott explains how to TIG weld carbon steel with multipass fillet welds. He is using the TIGWELD 200 EX model and explains the process, technique, and form.
For more videos, subscribe! Also, join our welding forum at www.freeweldingforum.com
The Longevity Learning Lab explains how to weld aluminum to get full penetration on a BUTT WELD.
For more, subscribe and join our welding forums
Check out our newest video! In this video segment of the Longevity Learning Lab, Scott is using the TIGWELD 200EX to show you the TIG method of walking the cup on a multipass corner weld.
Subscribe to our channel, comment, and join our welding forum.
Gotta see this really cool video! Scott shows one of the biggest welding projects in the bay area explaining the bay bridge welding going on with the retrofit.
To learn welding, join our welding forums.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
14 Gun Fireproof Safe (New/Unused) (A59225)
14 Gun Fireproof...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
JOHN DEERE 5105M TRACTOR (A58375)
JOHN DEERE 5105M...
