Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
Hey Everyone!
Look at this very cool bulldog piece that our forum member BucketObolts created.
For more welding pictures and welding projects check out our Longevity forum.
Longevity
Hello Everyone,
In this video of the Longevity Learning Lab, we explain the differences in stick welding rods from diameter, size, and types. This video is meant to help you understand the different types of stick welding electrodes that are out there in the welding world.
Longevity
Hey Everyone!
Check out this very cool Predator welding project that our forum member ironheartram posted.
For more welding projects and welding pictures check out our Longevity forum
Longevity
Hey Everyone!
In this episode of the Longevity Learning Lab, Bruce goes over Inert Gas and the differences of gases while welding.
Gas metal arc welding (GMAW), sometimes referred to by its subtypes metal inert gas (MIG) welding or metal active gas (MAG) welding, is a welding process in which an electric arc forms between a consumable wire electrode and the workpiece metal(s), which heats the workpiece metal(s), causing them to melt, and join. Along with the wire electrode, a shielding gas feeds through the welding gun, which shields the process from contaminants in the air. The process can be semi-automatic or automatic. A constant voltage, direct current power source is most commonly used with GMAW, but constant current systems, as well as alternating current, can be used. There are four primary methods of metal transfer in GMAW, called globular, short-circuiting, spray, and pulsed-spray, each of which has distinct properties and corresponding advantages and limitations.
Longevity
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2010 Kubota ZD326 60in Zero Turn Mower (A55851)
2010 Kubota ZD326...
2012 CM  T/A ENCLOSED 14 TRAILER (A55745)
2012 CM T/A...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
