jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,059
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Jim,
It's limited by being 2WD, but otherwise more comparable to the small Kubota than you acknowledge. I've owned both a Simpliicty with loader and a small Kubota with loader, so I can speak from first hand experience ...
Kent, I just don't see the comparison. The Kubota BX series all have water cooled 3-cyl diesel engines and the Simplicity has a air cooled Kohler. The Kubota has a hydraulic pump capacity of 6.3 gpm and the Simplicity uses the HST pump for power steering and adds a gear pump for the optional loader. The Kubotas weigh in at approximately 1200-1600 lb and the Simplicities are around 800-1200 lb. The Kubota has an implement lift that can lift 600 lb, I couldn't even find the spec for the Simplicity or the spec for it's add-on hydraulic pump. Add the 4wd and the two range HST transmission of the Kubotas and that puts them a class above the Simplicities. The BX also has rear 540 and mid-2500 rpm PTOs.
I don't mean to say anything bad about the Simplicity. I just say its not designed to compete with the Kubota BX in all aspects. It's a GREAT mower and garden tractor with it's 3PH. It doesn't need to be compared to anything. BTW: Was the photo you posted your Simplicity with loader? The wide aggressive tread tires with huge weights and the lightweight loader in that photo tend to bear out what I'm saying. The photo posted by the OP seems to show a homebrew loader that is much heavier and will set the Simplicity on its nose with much more than a bale of hay in the bucket, especially if the operator forgets and gets off to unload that bale while the loader is in the air.
I just think the OP has a great little tractor even without knowing what he paid for it. Trying to get an old loader or retrofit a newer loader to that machine will take a lot of time and expense that could be used enjoying a great piece of equipment. I just think it should be used for what it does best. It's no skin off my nose either way, but I can't let somebody go down a path without raising a red flag. If he chooses to go ahead, of course I wish him the best and hope that I'm full of prunes and he'll be very happy with the loader.
