Looking at 2 compact tractors (which one?)
   / Looking at 2 compact tractors (which one?)
New Holland dealers will work on fords?
   / Looking at 2 compact tractors (which one?) #12
If you are interested in the Ford take a look for stress cracks where the front axle is welded to the frame. I had a 1310 and the front axle came OFF the tractor when these welds failed. Easy keeping nose of tractor off ground but sure hard to drive anywhere.
   / Looking at 2 compact tractors (which one?) #14
Those are SCUT for sure.. not CUT.
really close on hp.. 1 hp either way.
the ford will have about 9% more 3pt lift capacity.
either COULD have live pto, depends.
I can't talk about the parts on the cih/mitsubishi.. but I know some front end parts for scut fords are harder to find than larger models.
cih could be 86-90 I believe, and the ford 20 series is somehting like 87 thru late 98
which one is in better condition?
go look up a front drive shaft for each and see if either are available?
how are the prices in comparison?
ford sn is on the trans bellhousing aft of the starter if you want to get the date.. see which is newer.. etc..
check trans type for both..
soundguy
An International 245 is not a SCUT. It's a CUT for sure. It is the size of the old B series Kubota at least.
   / Looking at 2 compact tractors (which one?) #15
Sound guy has his own standards as to which is which!
It's amazing as to where the horsepower has gone in the last thirty years!!!!!
Sometimes its best to go by tire sizes, but years ago even garden tractors had bigger tires!
   / Looking at 2 compact tractors (which one?) #16
I was just going by machine sizes. to me.. if it's rider lawnmower sized.. it's a scut. if it needs a 16' trailer to move it.. it's cut.. ut and up from there :)
soundguy
   / Looking at 2 compact tractors (which one?) #17
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2013 GREAT DANE 53FT REEFER TRAILER (A54607)
2013 GREAT DANE...
CUTTING TORCH (A53843)
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
