RoyKing
Platinum Member
Used ham radios, no license.
Excellent advice. We have Motorola radios at work (a mix of CP200, CP200d, CM200, and whatever preceded the CP200, something 150 IIRC, etc).Rechargeable batteries are fine but they must be in good shape. One failed battery and you reduce your power output tremendously. Along that line, battery charge indicators are near worthless as they usually measure voltage but not an ability to produce power. If your concerns are having a radio during a disaster, you could use rechargeable but I would have a good set of alkaline batteries at the ready. Below is a test I did to convince firefighters (actually chiefs) that they should head the advice of our radio tech guy and just replace rechargeable batteries on a regular schedule even when testers and meters show they are good.
Don't do that unless you like paying FCC fines...Used ham radios, no license.
Used indoors 1-2 miles? That's pure fantasy.Buy quality GMRS hand sets and you will get excellent service...have been using units purchased for less than $50 for over 8 years in the exact same scenario as described by the OP without any reception issues...why some are making it more complicated is beyond me...!
BTW...mostly used indoors with a avg range of 1.5- 2 miles with no external antenna etc...
I was looking at this hand held ham radio Baofeng UV82-HP and getting my license.
Thanks James I will do that.Being retired now have extra time on my hands always wanted to get into Ham radio.No time better than the present as it has always been on my bucket list of things to do.If you need any help, or info, let me know.
Thanks..There is a very, very wide range of equipment to look at and consider once you are licensed.
If you like to learn new things, I think you will enjoy getting your license. My wife and I took classes together, and obtained our Technician and General licenses ratings at nearly the same time. Two separate tests were required to do that, but we found them so close in required knowledge to do both. After only the initial training for the Technician license, we took that test. About a week or two later we took the General test. Easily passed both. And my wife is not "technical" at all-- at the start of the training she did not know how many volts were in a typical car battery.
Cost? I think we each made a suggested donation of $15 each to the instructor, and I don't remember any fee for the test or license. If so it was minimal.
The license requires some learning, but is not difficult. The requirement to learn morse code was dropped some time back. Once that was eliminated achieving a license became a lot less difficult.
