Looking at a John Deere 3130....Any advice
   / Looking at a John Deere 3130....Any advice #1
LondonDave
Melbourne, Ontario Canada
John Deere 5410 MFWD, Case IH 5230 MFWD
I've done some reading. Seems like they have some hydraulic issues. The seller tells me the hi/lo is working. The tach and hour meter aren't. Brakes work. Apparently it runs good, doesn't smoke. It has a 158 loader on it. Is this a tractor I should stay away from because of the hi/lo and various other hydraulic/transmission issues it seems to suffer from? I'm going to look at it on Saturday. Is there anything specific I should look closely at?
Thanks
Dave
   / Looking at a John Deere 3130....Any advice #2
Hi-Lo is a big issu .....Here in South Africa all has been removed . You can not runstart those tractors .
IPTO .....CHECK FOR PTO BRAKE
Mainpump ......check for erratic lift at 3point (vibration while lifting)
Steering ......check for oilleak just under steeringwheel
Then remember it is allmost 40 years old
   / Looking at a John Deere 3130....Any advice #3
I would recommend to acquire a coolant test kit and test coolant PH
   / Looking at a John Deere 3130....Any advice #6
A 3130 LS is the most problematic Deere tractor I have ever dealt with, never could get the hydraulics, steering and lift to work well. Sold it and good riddance.
Thanks for the info. I didn't end up buying it. Too big for my needs.
   / Looking at a John Deere 3130....Any advice #8
We had 2 of them and both were awful , Hyd problems , brake problems , head gaskets . Right from new !
2015 Ford F-350 9ft Crew Cab Dump Truck (A44571)
2015 Ford F-350...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A44391)
1996 International...
2016 Ford Escape S SUV (A44572)
2016 Ford Escape S...
Ford 1510 Tractor with Loader (A44391)
Ford 1510 Tractor...
2012 Kubota ZD331 72in Zero Turn Mower (A44572)
2012 Kubota ZD331...
Ver-Mac Message Board S/A Towable Trailer (A44571)
Ver-Mac Message...
